Please advise , how to install the load determination sw using a regular usb stick on krc2?
installing load data determination sw to krc2 i've the sw on non bootable usb
- bayeh6
there are different ways, one of them involves reading included documentation, in particular section called installation...
basically you either install it through kuka HMI (login as expert, menu Setup, ... software install...configure...set path...etc.)
OR...
prevent KSS from starting and then install it like any other software (run Setup.exe). this can be done by holding CTRL on boot ... or... login as expert, turn off NUM, press CTRL+ESC, delete startup shortcut from Start>Programs>Startup (do not empty recycle bin, so you can restore the deleted shortcut later on), reboot (no hmi will load), install software, when done restore deleted shortcut...
