We have some brand new M-710iC/50 robots with R30B controllers. When we teach a joint move position with our other robots the robot will always return all 6 axis's to the same position when told to go to that position.
On these robots after we teach a joint position and then move the 4th axis (which turns the end effector) when we tell it to go back to the taught position the 4th axis stays turned and the 6th axis rotates. The end effector is in the same position as taught but the 4th and 6th axis are not the same. This is a concern because when we return to the taught position normally all the axis's return to the position as taught and keeps all the cables from getting wound up.
Any ideas. I thought any taught Joint move always keeps the same configuration when returning to it.
