I've a strange problem using Workvisual 3 to configure an Ethernet/IP network.
I can configure the KRC as an adapter and this works fine, but I can't configure it as a scanner. I've documentation, but that's for WoV 2.
The issue is that there doesn't seem to be anywhere to configure the amount of I/O which the adaptor (a Festo valve island) has after you add it. After adding the Class 1 server to the adapter there is a screen, but the only thing which can be modified is the RPI.
When you check the I/O mapping there are 4 bytes in and 4 out available on the Fieldbus....but no indication where this comes from!
The screenshot shows it all!
