Hi Fanuc experts,
Is there a way to connect multiple HMI's to a Fanuc Robot R30-iA controller?
I currently have a Proface HMI talking fine over Ethernet.
However when I try to connect a Red Lion HMI to the same robot I get a "PRIO-096 SNPX Connection is full <172.21.118.101>" error when both are connected. (The IP address is the Red Lion HMI).
Both HMI's work fine with the robot if only 1 is connected, however when I plug the 2nd HMI in, I get this error no matter the configuration I try.
I have tried to put both HMI's onto the same Robot Ethernet port (Port A) and also on both the Robot Ethernet Ports (Port A & B with different IP ranges), yet still doesn't work.
Any ideas out there??
Thanks,
