I was trying to eliminate the issue of the "Download" bar filling up, emptying, filling up, etc. over and over for nearly 15 minutes. When the control screen finally comes up, a message says that the download timed out. Is that a setting I can change & make super-short (even if it's in the registry)? ***NOTE***After typing all of this, I have deduced that my attempt to use different SDRAM is at least partially responsible. I have the original RAM back in the cabinet, and the lengthy "Download" has disappeared, but it's too late, hence the rest of this lengthy posting.
I decided to try with a completely clean slate, so I re-installed the system software, which is V3.2.6 SP03. Unfortunately, now I have a robot that says "no axes need mastering" when the control screen comes up, and if I choose the "GM" option at install, I have the dreaded "general motion enable" message. Also, no matter which option I choose, the "S&I" icons immediately come up green...why is the "I" icon green, (I know it means the motors are already on..but WHY) ??
Pushing any of the deadman switches does not change the color of the "S" or "I" icon. I do hear relays clicking...
I'm also getting these silly messages:
-"BOF Statuskeys refer to a technology not loaded"
-"UserStatuskeys refer to a technology not loaded"
-"UserStatKeyBarOCX Unknown Module "KUKATPGRP at Statkeybar request"
I went back through my entire message history on this forum, and those messages didn't come up when we first tried running this thing back in August.
I have looked inside at the control PC. There are several boards (this info may be important later):
-X834 (green connector)
-X801 on left side (green connector) and X802 on right side
-X821 (monitor is plugged into this one)
-COM2
I proceeded with the re-install. My first attempt is with the following selections :
-Office PC
-Kuka Standard
-No folders chosen for use of existing installation
I chose KR30_2 Floor for robot type.
The next screen is particularly frustrating, as I don't know exactly which options to check, and if any of these options are affecting the overal problem of the robot not budging an inch right at startup. Even with my limited knowledge, I'm almsot sure a few of these should be checked, based on the info I mentioned earlier about what's physically in the computer.
-Interbus
-DeviceNet
-Bosch
-Perceptron
-Sbip
-Fipio
-Profibus-Slave
-Profibus-Master
-RIO
-LIBO
-Profibus Master-Slave
-LPDeviceNet-Scanner (Channel 1)
-LPDeviceNet-Scanner (Channel 2)
-DSEIODRV
-LPDeviceNet-Scanner (Channel 3)
-LPDeviceNet-Scanner (Channel 4)
-LPDeviceNet-Scanner (Channel 5)
-LPDeviceNet-Scanner (Channel 6)
I have also tried searching the forum extensively for the whole "$MOVE_ENABLE to 1025" issue, but that is frustrating me. Why are there TWO locations (R1 and STEU) that have a file called machine.dat??? I've attached a screenshot of what the applicable settings are right after installation.
I didn't realize it at the time back in August, but I guess we shoulda made a backup image of the hard drive IMMEDIATELY after getting the whole setup to work. I myself was not the one who initially looked at the machine.dat, etc files for configuration issues.
I think my only option at this immediate point is to recheck the X11 plug my friend made, but that hasn't changed, been moved, etc....GRRRR!
I promise to keep excellent records, make backups, etc. this time if y'all can graciously help me regain control of my robot. Thanks!
