Good day.
sorry for my english.
I have a problem
the robot performs no movement 100%
the shop floor negative temperature (about -10 ° C), perhaps because of it?
or I heard that Kuka robots have a problem with the fourth and second axes (can not operate simultaneously at high speed)
is this true? or other options?
Thank you for your help.
not running at full speed
- Aquilon
robot type and software version please ?
Robot KR 16 L6-2(used for welding)
KRC 2 -
+5 ° C is the lowest allowed temperature for manipulator.
At around -10 ° C oil can block gears.
May be you can setup long warm up program before using at full speed.
I have recently been working with robots ... how to do it?
open #machine.dat and search for $WARMUP_RED_VEL (there are few more variables that follow, such as $WARMUP_TIME=30.0). if you plan to use robot at such low temperatures, you should consider Arctic version, it is made for low temperatures.
Beat me to it
Sent from my Nexus 5 using Tapatalk
Thanks for the help all.
and whether there is a known problem, as I was trying to convince some people of the A4 and A6, that they can not work together at high speeds?
A4 and A6 can work together at high speeds for PTP motions. However, for LIN motions, if A5 is too close to 0deg, A4 and A6 will attempt to compensate by rotating in opposite directions at increasing speed until an over-speed fault occurs.
