Hello everyone,
When I learning all kinds of RSI objects to communicate with PC, I fond some objects were hard to understand. Firstly, ST_Ethernet has a lot of parameters but in RSI 2.3 manual there was not described. eg, err=ST_MAP2DIGOUT(hMapDio,0,hEthernet,19,2,2), the ST_Ethernet object hEthernet's parameter 19 stand for what?
Thanks for any idea~~
RSI object ST_Ethernet
jane3von -
January 14, 2014 at 10:32 AM -
check bottom of page 55, all parameters are listed (output index of the signal source)
maybe this helps a bit
maybe this helps a bitI fond the parameter 19 here was means the number of the output of the signal source but not the output index ? Can I understand the signal in its explanation as the input data from PC ?
