How to make secreenshot??(krc4)
KRC4 Screenshot
- RoboterTurkey
Hm. That's a good question. My first thought is to plug in an external keyboard and use the PrntScrn key. But would you need to plug into the SmartPad, or directly into the KRC? As long as you plug into the correct unit, PrntScrn should work, after which you can shrink the HMI, open up Paint in the Windows menu, then use Paste. Save the resulting image to a USB memory device, and that should do it. But I haven't tried this.
Plug the keyboard directly to the SmartPAD..
I will try tomorrow and write here..
...but, when I take KRC diag then I found screen shots in the diag? How is it?
I just RDP to the robot and capture that screen
Haven't tried the keyboard way, but the problem would be what you do with the screen capture afterwards, as I'm not sure if the SmartPad has Paint installed?
Sent using Tapatalk 4
Hi, guys.
The keyboard must be plugged on SmartPad USB. It will don't work on controller ports.
And my procedure to obtain screenshots on (v)krc4 is:
- plug a usb keyboard on SmartPad port
- use the print screen key
- paste the result on Windows Paint
- save the .bmp on a usb stick plugged in a controller port -
I tried but it didn't work. I think, I must use different mark or model keyboard
KRCDiag
KRCDiag_KUKA2013-06-21T13_49_13.zip\Screenshot -
I want shortcut of the screenshot. when I take a KRCDIAG then I can found as you told me but I want to take directly screenshot. It should be away like CTRL+X or CTRL+V ..
Virtual pendant is a great way to take screenshots if you have it available.
Hello colleagues,
with our new and free app "Screenshot" you can perform screenshots directly on the SmartPad at the touch of a button.
For more information visit:
http://www.orangeapps.de/?page=apps/screenshotHave fun with this app!
Your OrangeApps-Team -
For capturing screenshot ,
Firstly Connect Pendrive to USB slot provided at controller , then Double press Menu Key provided at bottom right of SmartPAD , current screen screenshot will be directly saved in the root folder of Pendrive.
For capturing screenshot ,Firstly Connect Pendrive to USB slot provided at controller , then Double press Menu Key provided at bottom right of SmartPAD , current screen screenshot will be directly saved in the root folder of Pendrive.
Is this using OrangeApps' Screenshot plugin, or is this a built-in KSS function now?
well, recent versions of KSS do have a screenshot ... sort off...
but... that is one hell of an obscure feature....
In fact ONE CANNOT SEE ANYTHING at all... (before, during or after capture).
one must know how to use it (secret handshake), hope that it worked when you wanted (no feedback) and know where to go to retrieve files... (sigh...)[size=1em]
orangeapps made a free plugin, which is far better because:a) it works on any KRC4, regardless of KSS version
b) it is intuitive (there is an icon to click on to make a screenshot)
c) it displays message that image is taken and where it got saved (with file name)[/size]
Thank you orange apps, i was about to make one myself...
