Hello all. I am working on a project that consists of four Fanuc RJ3I robots. I have been trying to set up the tool adjust manual function for the customer so that they can have an easier time touching up points in the event of a robot crash. I have been following the manual step by step. I make a program called MOV_REF1, I make it move to my reference position, and I record the reference position to a position register using LPOS after it reaches the point. However, I run into an issue when I try to actually run the tool adjust manual function. The robot will move down to the reference position fine, but when I try to move on to the next step, it says that the robot is not at the reference position! I get this error on 3 out of the 4 robots. Only one of them works. I have verified that I have the correct PR and tool selected when I start the manual function, and I have also compare the coordinates of my position to the PR to make sure that they are the same. I have talked to Fanuc a little bit about this as well, but they have been of little help. I was wondering if anyone else has run into a similar issue, and if there is a remedy if so.
Thank you for your time on this matter. I appreciate it!
