Kuka ORI1 ORI2 Swivel vs Orientation
  • Hi,
    kan someone please explain the difference between the ORI1 and ORI2 concept?
    ORI1 is referred to as the swivel velocity. Is the swivel the joint 5 and 6 ?
    ORI2 is referred to as the rotation, of the TOOL? In all directions? Or?
    In german it is:
    $VEL.ORI1 = Schwenkgeschwindigkeit
    $VEL.ORI2 = Drehgeschwindigkeit
    I have multiple Kuka pdf's but I can't find an explanation.
    I have read:
    http://www.roboterforum.de/rob…-relativbewegung/msg11145
    but still don't get it.
    I have: Startup Manual / Configuration Manual / Operating and Programming instr / KRL Reference guide / Expert prog manual / System variablees / and some others.
    Maybe someone give an example of each motion?
    I assume it has something to do with the orientation velocities of the TOOL-frame.
    I assume:
    $IPO_MODE = #BASE
    $BASE = {FRAME: X 0, Y 0, Z 0, A 0, B 0, C 0}
    $TOOL = {FRAME: X 0, Y 0, Z 0, A 0, B 0, C 0}
  • Place your Ad here!
  • can't you just try it (make a test program) and watch it...
    ok here is my attempt to explain it based on my understanding:
    think of a spherical coordinate system, any position can be reached/represented using radius and two angles.
    http://en.wikipedia.org/wiki/File:3D_Spherical_2.svg
    radius is distance from origin (but here we don't really care about it)
    rotation about Z is the first angle (controlled by $vel.ori1)
    tilt away from Z is the other angle (controlled by $vel.ori2)
    did a job not long ago and customer configured tool such that Z-axis was normal to flange (X and Y were aligned with base) so rotation about Z was basically rotation of A6. to limit the velocity for rotation about Z axis I used $VEL.ORI1... other rotations about TCP would then be ORI2...
  • The $VEL.ORIx values do not refer to wrist axes at all. They refer to the rotation of the TCP orientation in Cartesian space. I don't have the specifics in front of me, but I believe 1 is the rotation around the Z axis, and 2 refers to the vector sum of rotation about the the X and Y axes. I believe these are the TCP axes, rather than the axes of the active Base. The units are deg/sec.
