Reading a user frame into register
  • Sergei Troizky
  • October 16, 2013 at 11:58 PM
  • Sergei Troizky
    70
    658
    I need to read a component of a user frame into a register, on R-30iB.
    I tried PR[x]=UFRAME[n], but this results in strange content of the position register,
    something like NX=1mm, NY=0mm, NZ=0mm, OX=0mm, OY=1mm, OZ=0mm,
    which has nothing with the user frame values.
    I tried then to read the component of the $MNUFRAME system variable directly,
    but could not discover the proper syntax for the parameter name.
    Would greatly appreciate any help on both issues.
  • Nation
    Typical Robot Error
    544
    1,924
    • October 17, 2013 at 3:56 AM
    What you are seeing in the PR is the first 6 components of a rotation matrix. If you hit the page key (F2 I think) when viewing it you will see the remaining 6 components.
    Turn $PR_CARTREP to True in the system variables. This will make the PR in a PR[XX]=UFRAME[X] command show up in normal Cartesian representation and not in matrix representation.
    Of course this very useful system variable isn't documented...
  • scotty
    43
    5
    497
    • October 17, 2013 at 8:13 AM
    PROGRAM a1
    %COMMENT = 'cool job'
    %ENVIRONMENT REGOPE
    %ENVIRONMENT SYSDEF
    %ENVIRONMENT KCLOP
    VAR
    xyz	: XYZWPR
    STATUS	: INTEGER
    BEGIN
    xyz = $MNUFRAME[1,1]
    SET_POS_REG(1,xyz, STATUS)
    END a1
  • Sergei Troizky
    70
    658
    • October 17, 2013 at 2:39 PM
    Thank you, Nation, it worked.
    I also would like to directly read a user frame component into a register.
    This will be done in TP format BG logic, so reading to position register cannot be used.
    What would be the syntax for this? Say, I need Z of Uframe 1.
    R[1]=($MNUFRAME[1,1]???). How to refer the Z component?
  • Nation
    Typical Robot Error
    544
    1,924
    • October 18, 2013 at 2:31 AM
    Quote from Sergei Troizky
    I too would really like to know how this is done, assuming it is even possible. I even had a thread here, but no one was able to give me an answer.
  • scotty
    43
    5
    497
    • October 23, 2013 at 8:54 AM
    Why u not want to use Karel, Macro, BG. Their bunch can help to solve a problem. In BG u put flag ON. When this flag is put ON then macro is called. In macro u called Karel program when u got in numeric register Z component of UFRAME. And in ends of karel program u put flag off. In BG u saw when flag is OFF then u take from register needed data.
    If u think that is bad idea pls say^)
  • Sergei Troizky
    70
    658
    • October 23, 2013 at 2:39 PM
    Karel is out of question. Our policy is to stay with TP format.
    I do want to do this in BG, where I cannot refer PR[n], only PR[n,c].
    All this being said, can you explain how a macro can help?
  • scotty
    43
    5
    497
    • October 23, 2013 at 3:08 PM
    I think u can without Karel do it. Two choise:
    1. If u TeachPendant is off:
    Write BG to put flag for macros. In macros write PR[n] = UFRAME[m]; R[y] = PR[n,j] just like this. And in end of macros back macro flag to OFF.
    2. If u TeachPendant is on:
    its choise is difficult. But We can in run start TP program to read flag from BG and back datas of UFRAME in numeric register and say that to BG. because I not find how can to start the macro when TP is on^(
    Edited once, last by scotty (October 23, 2013 at 3:12 PM).
  • freemanleon
    21
    • November 7, 2013 at 6:17 AM
    Even though I will do this in some easy way, scotty's Karel is still much more insteresting.
  • scotty
    43
    5
    497
    • November 7, 2013 at 7:26 AM
    thx
  • Andres Romero Romero
    • March 5, 2022 at 8:02 PM
    • #11
    Quote from Nation
    • March 5, 2022 at 8:04 PM
    • #12
    Just to say thank you. The PR_CARTREP was like a kind of tricky. Thank you so much, very useful
