Hi, I have KRC1. I want configure Automatic External command. How can it. In my opinion, X11 socket. where I find X11 circuit diagram document? I want Circuit diagram. Please help.
Automatic External Connection
- hydra
Thanks.
Here you can find a detailed description of how to make automatic external mode work:
http://www.loullingen.lu/projekte/kuka/index.php?language=EN
I do not take over any warranty or responsability for any damage that might occur when following my instructions. You do this at your own risk.
Loulli The waits you have inside the SPS is a very bad idea and not the correct way to do that IMHO
Something like this would be better
Edge= ($date.sec-($date.sec/2)*2==0)
IF AUTO_START_PRESSED AND $EXT AND $ALARM_STOP AND EDGE AND NOT $PRO_ACT THEN
PULSE(DRIVES_ON,NOT $PERI_RDY,0.2)
PULSE(CONF_MESS,$STOPMESS AND $PERI_RDY,0.2)
PULSE(EXT_START,$ON_PATH AND NOT $PRO_ACT AND $STOPMESS,0.2)
ELSE
DRIVES_ON=FALSE
CONF_MESS=FALSE
EXT_START=FALSE
ENDIF
meh... those wait are not blocking so SPS will still run. more over they are not processed continuously, only processed when start button is pressed.
i would not worry about it
I still would have any waits inside the SPS IMHO Also depends if he has anything in sps
Here you have a PCB for the automatic external Start , without devicenet needed
External Content www.youtube.comContent embedded from external sources will not be displayed without your consent.Through the activation of external content, you agree that personal data may be transferred to third party platforms. We have provided more information on this in our privacy policy.
