Hi
We have KUKA KRC2 version 5.5.11
I have used FOR loop, but it is behaves stange.
It is counting 1 then 3 then 5 .However I used STEP 1.Still it is incrimenting in 2.
The .SRC file is enclosed.
Hi
opening all folds reveals in line 109 (;FOLD LIN P20 ...)
COUNT=COUNT+1
Hence you get an additional +1 per loop.
Fubini
yup - it's hidden in L36 LINP20
Now it is working.
I have another problem.many times I am not able to edit the program on KCP.I have checked the file attributes,but read only is unchecked.
I have enclosed the Archive.
Regards
JAgroop
What kind of edit did you try to make?
Were you in Expert mode? If it wasn't an inline command was the program selected rather than open by the edit command?
Sent using Tapatalk 4.
Yes, I am in Expert Mode
Iam trying to edit some logic command or any variable in .SRC file then it get deleted for a moment but when I move the cursor on the next line then the deleted line appears again.
Then I tried several times to Reset and cancel the program and edit again.But same thing happen.
There is no sign of link appears on the program.
Sounds like you pressed Select rather than Edit/Open?
HI,
Problem solved.
I was opening file by pressing "ENTER".
Rupy
