Writing my own home check (instead of P00 CHK_HOME)
  • JonHopper
  • July 23, 2013 at 1:44 PM
  • JonHopper
    150
    Quote
    $H_POS=XHOME
    IF CHECK_HOME==TRUE THEN
    P00 (#CHK_HOME,#PGNO_GET,DMY[],0 ) ;Testing Home-Position
    ENDIF
    This is the original snippet from the basic cell.src template.
    Is the $H_POS=XHOME line necessary? Aside from that I am going to be writing my own home check..
    I basically have three home positions from which I would like the robot to be able to start. XHOME, XHOME1 and XHOME2. I was planning on writing a fairly basic if statement to check for one of three positions. Has anyone done this? I am just wondering if I will run into any unexpected issues from doing this. Thanks.
  • eusty
    721
    • July 23, 2013 at 2:29 PM
    Basically $h_pos is what it looks for for the home position, you are just making it to be the same position as XHOME.
    I think this is to make it backward compatible with older versions of KSS, I've never used multiple home positions but there was a thread about in the other week or two.
  • JonHopper
    150
    • July 23, 2013 at 9:12 PM
    Can't seem to find anything relevant.
    I'm not really too worried about it. A simple if statement check should do the trick...
  • eusty
    721
    • July 23, 2013 at 9:50 PM
    https://www.robot-forum.com/robotforum/ind…38534.msg#38534
    Sent using Tapatalk 4.
  • JonHopper
    150
    • July 23, 2013 at 10:03 PM
    I know already that I can assign up to 6 home positions... my question is more specifically regarding the home check in cell.src. Will any one of the home positions create a chk_home=true condition?
    I need to be able to completely abort all programs and start back up from cell.src in any of the home positions :smiling_face:
  • eusty
    721
    • July 23, 2013 at 10:36 PM
    It depends on what sets CHECK_HOME true.
    We don't use the standard cell.src but create our own main program so without checking the whole program I couldn't say :frowning_face:
  • JonHopper
    150
    • July 24, 2013 at 5:55 PM
    It appears P00 home check only looks at $IN_HOME which is xHOME, not any others... so P00 calls an If statement. I'm just going to skip all the nonsense and put my own check in..
    Thanks for the help anyway. I'm 97.5% sure my own check will work without any issues. I'd really like to not use any p00 functions if I can help it.
    SkyeFire
    1,061
    9,463
    • July 24, 2013 at 7:29 PM
    It's not hard to do. You can simply compare the values of $AXIS_ACT to your "home" position, using a tolerance band, like so:
    DECL BOOL CheckPassed
    CheckPassed = (ABS($AXIS_ACT.A1 - MyHomePos.A1) < Tolerance.A1)
    CheckPassed = (CheckPassed AND (ABS($AXIS_ACT.A2 - MyHomePos.A2) < Tolerance.A2) )
    CheckPassed = (CheckPassed AND (ABS($AXIS_ACT.A6 - MyHomePos.A6) < Tolerance.A6) )
  • JonHopper
    150
    • July 24, 2013 at 7:58 PM
    I was thinking of something even simpler...
    IF (($AT_HOME=1) AND ($AT_HOME1=0) AND ($AT_HOME2=0))
         HOMECHECK=TRUE
    ELSE
    IF (($AT_HOME=0) AND ($AT_HOME1=1) AND ($AT_HOME2=0))
         HOMECHECK=TRUE
    ELSE
    IF (($AT_HOME=0) AND ($AT_HOME1=0) AND ($AT_HOME2=1))
         HOMECHECK=TRUE
    ELSE
    HOMECHECK=FALSE
    ENDIF
    ENDIF
    ENDIF
    Would this not work?...
    SkyeFire
    1,061
    9,463
    • July 24, 2013 at 8:27 PM
    Ah, well, if you have all the various HOMEx positional variables set, then yes, that'll work. Although this might be simpler:
    HomeCheck = (($IN_HOME1 EXOR $IN_HOME2) EXOR $IN_HOME3)
    Reduces it down to one line.
  • JonHopper
    150
    • July 24, 2013 at 8:37 PM
    • #11
    Hah, yeah didn't think of that. Doh :stupid: basic logic anyone ...
    Thanks :grinning_squinting_face:
  • JonHopper
    150
    • July 25, 2013 at 2:30 PM
    • #12
    Here's another way to do it: (for reference)
    CHECK HOME
      IF ($OUT[59]==TRUE) THEN
      $H_POS=XHOME1
      ENDIF
      IF ($OUT[60]==TRUE) THEN
      $H_POS=XHOME2
      ENDIF
      ENDIF
    This is under the assumption that 59 and 60 are already configured for home 1 and home 2. This way is not really that great as all you are doing is modifying home0 (as I call it) to reflect home1 and home2 so you can pass the silly p00 homecheck which only checks H_POS.
    It is also possible to add a few lines in P00 to check for the other home positions but to me this seem the longwinded way of doing it...
    SkyeFire
    1,061
    9,463
    • July 25, 2013 at 4:02 PM
    • #13
    Yeah, since the Signal assignments can change, the better way is to simply access the $IN_HOMEx variables directly.
    P00 isn't holy writ -- it's intended as much as a template as an actual ready-to-use program. There's no reason you can modify the Home Check section of P00 for your own application.
  • JonHopper
    150
    • July 26, 2013 at 3:05 PM
    • #14
    The reason I'm trying to stay away from it is to make the program easier to understand for operators and on the floor techs. There are a lot of people that get confused when variables are passed back and forth between routines and/or when the operation of the code isn't extremely obvious...
    This is my new cell.src:
    DEF  CELL ( )
      ;FOLD INIT
      DECL CHAR DMY[3]
      DECL BOOL HOME_CHECK
      HOME_CHECK=FALSE
      DMY[]="---"
      ;ENDFOLD (INIT)
      ;FOLD BASISTECH INI
      GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
      INTERRUPT ON 3
      BAS (#INITMOV,0 )
      ;ENDFOLD (BASISTECH INI)
      ;FOLD CHECK HOME
    HOME_CHECK:
    HOME_CHECK=(($IN_HOME EXOR $IN_HOME1) EXOR $IN_HOME2)
    IF (HOME_CHECK == TRUE) THEN
    	DO38_AT_HOME=TRUE
    ELSE
    	DO38_AT_HOME=FALSE
    	;WRITE MESSAGE
    	GOTO HOME_CHECK
    ENDIF
      ;ENDFOLD (CHECK HOME)
    $OUT[18]=FALSE
      LOOP
        SWITCH  GI_JOB_SELECT
        CASE 1
          JOB001() ; Call User-Program
        DEFAULT
          ;MESSAGE
        ENDSWITCH
      ENDLOOP
    END
  • eusty
    721
    • July 26, 2013 at 4:32 PM
    • #15
    Another way to make things easier to understand.....why not use SIGNAL declarations?
    SIGNAL name $OUT[18]
    The you could use name=FALSE in your program, which would be easier for others to work out what is being set false.
  • JonHopper
    150
    • July 26, 2013 at 5:34 PM
    • #16
    Yes, I realized that yesterday and drew up the IO declarations for each robot. It will help big time, the way I was doing it before I had to add comments everywhere there was IO...
    My question is though, where and when do the signal variables get updated? Do they get updated at the exact same time as the IO table or do they have to run through a scan first?
  • eusty
    721
    • July 26, 2013 at 6:52 PM
    • #17
    As far as I'm aware it's just a tag for the I/O so gets updated as the I/O does.
    SkyeFire
    1,061
    9,463
    • July 26, 2013 at 8:39 PM
    • #18
    Eusty is correct -- from the system perspective, $IN[1] is no more, or less, valid a "handle" to a given bus signal than any SIGNAL declaration you make yourself. The only difference is that $IN and $OUT are "baked in" at the factory. But input updates are all simultaneous, and all outputs are effectively instantaneous (interrupt-driven).
  • JonHopper
    150
    • July 26, 2013 at 9:59 PM
    • #19
    Awesome. Thanks for the info, guys.
