  4. ABB Robot Forum
39103 Drive System Error
  • LuiCastor
  • July 22, 2013 at 10:36 PM
  • LuiCastor
    how do I go About fixing this error. it says "DC-Link Incoming Mains not Valid,Drive System 1". "check Voltage from Motor On contactor. Replace DC-Link.". Dc-Link has been Replaced, Voltage from contactor is 262. What can I look into next. Robot has been down a week and we are unable to fix this problem. :help:
  • red0492
    Guest
    • July 25, 2013 at 10:49 AM
    We had this tonight when we came in. Replaced K2 and Aux adder block. So far so good.
    Theory is that contacts on adder block were bouncing.
  • LuiCastor
    • July 25, 2013 at 10:30 PM
    Thanks for your reply Red0492. I will try that next.
  • psirca76
    7
    • June 9, 2025 at 2:54 PM
    • New
    Salve, a me è successo lo stesso problema, nessun tecnico riesce a risolvere.
    Potete dirmi esattamente cosa sono i blocchi K2 e il blocco aux, grazie
  • Skooter
    172
    2,051
    • June 9, 2025 at 10:18 PM
    • New
    What series controller do you have, S4C, S4C+ or IRC5?
    Which controller model, M97 .... M2004?
    K2 in the example would be the 2nd Motor On contactor along with its attached auxiliary contact block.
  • psirca76
    7
    • June 10, 2025 at 4:06 PM
    • New
    Salve, ho un s4 controller, m98 del 1999. Ho cambiato le.bobbine k2 e k1, ma devo aver invertito qualche cavo nel k2, ora mi dà errore 37001.
  • Skooter
    172
    2,051
    • June 10, 2025 at 4:40 PM
    • New
    Added manual at IRB6400 M98 manual
    This has the controller prints with K1 & K2 connections and wire #s on PDF page 419 (sheet 16 of 54)
  • psirca76
    7
    • June 10, 2025 at 4:56 PM
    • New
    Grazie mille, chiamo un elettricista e faccio controllare . Gentilissimo
  • psirca76
    7
    • June 13, 2025 at 4:48 PM
    • New
    Eccomi nuovamente qui... Purtroppo il problema non sono le bobine, a vuoto la tensione è 24, come collego le bobine la.tensione si abbassa a 8v. Non riusciamo a capire qual è l alimentatore.grazie a chi mi aiuta...
  • Skooter
    172
    2,051
    • June 13, 2025 at 8:30 PM
    • New
    With meter lead (1) connected to the controller frame, what voltages are at contactors K1 & K2 coils?
    Contactors off
    K1-A1 =
    K1-A2 =
    K2-A1 =
    K2-A2 =
    Contactors on
    K1-A1 =
    K1-A2 =
    K2-A1 =
    K2-A2 =
  • psirca76
    7
    • June 17, 2025 at 7:03 AM
    • New
    • #11
    Il mio problema deve essere la scheda di potenza. Alle bobine k1 e k2 attiva 8v invece di 24v
  • Skooter
    172
    2,051
    • June 18, 2025 at 9:30 PM
    • New
    • #12
    If you believe it a weak power supply, go ahead and change it. I have seen a few that would cause something similar.
    In my experience, it is usually a miswired contactor or something external in the runchain. It requires someone good with a meter and reading schematics.
  • psirca76
    7
    • July 3, 2025 at 12:30 PM
    • New
    • #13
    Ho cambiato sia le bobine che la scheda di controllo. L elettricista mi ha detto che i camblaggi sono validi, i contatti ci sono. Non so più cosa fare...
  • Skooter
    172
    2,051
    • July 3, 2025 at 10:56 PM
    • New
    • #14
    If you provide the voltages in post #10 above, we can narrow the problem.
  • psirca76
    7
    • July 4, 2025 at 10:20 PM
    • New
    • #15
    Il voltaggio dalla scheda esce a 24v, come spingo il pulsante di azionamento nella bobina k1 si abbassa a 8v.
  • Skooter
    172
    2,051
    • July 7, 2025 at 9:06 PM
    • New
    • #16
    Yes, you stated that before. Again, please provide voltages at A1 & A2 of each contactor while ON and while OFF. This will define which of the two run-chains is having an issue.
Users Viewing This Thread
  • 1 Guest
