Hi guys,
i have a question, just not sure how to deal with this:
I am doing milling on my robot - KRC2 v5.2. The programs usually are big - up to 70 000 - 100 000 lines, so i am dividing the code into smaller files - up to 2200 lines each.
That is working but as there is a limitation on my KRC - cannot load more than for example 25 files (dat and src) - so i am doing it part by part - deleting the old ones and copying the new files. It works, but is a bit of time consuming
So, my question is - what is the proper way to feed those files. Usually i am doing a base program, which 'calls' all the files - is there a way to use a USB stick for example? I've been told that the files for execution needs to be based into R1 folder. But the space is limited there :(. The KRC cabinet have two USB ports, CD, floppy and also a network card. Not sure about the software side but can check if needed...
Any advise will be appreciated!
Thanks!
