FORWARD Function
  • Hi,
    -2: the second parameter of your FORWARD() call has not yet a value assigned, e.g. the VARSTATE would be DEFINED but not yet INITIALIZED. So if your forward call reads
    FORWARD($AXIS_ACT, ERR_STATUS)
    assign a value to ERR_STATUS before calling FORWARD. This value could be 1 if you want a software limit switch check or 0 otherwise.
    Fubini
  • Hi Fubini,
    Thank you, that was the problem.
    Do you have any detailed description about those functions, or is it the basic error response?
    António Simões
