Syntax for pulling a position out of the system variables in TP
Nation -
June 25, 2013 at 5:28 PM -
The reason this isn't working is because you're trying to do it as a mixed logic statement. ...=(...) instead of just ...=...
However, you can't dump a parameter into a PR element directly, so you need to put it into a register first and then put that register into the PR element, like so:
R[98]=$LNSCH[1].$TRK_FRAME.X ;
PR[98,1]=R[98] ; -
Pulling from a system parameter isn't even an option if I don't use mixed logic.
If I point the PR at a number, or a bool, it works fine.
example:
However, I can't figure out how to access a sub component of a position. It always says invalid parameter name.
Stuff I have tried so far (all invalid parameter names.):
When I'm having problems finding the correct formatting for a system parameter I use the variable browser in Roboguide. If you browse to the desired variable there it displays the correct formatting in the same window.
When I'm having problems finding the correct formatting for a system parameter I use the variable browser in Roboguide. If you browse to the desired variable there it displays the correct formatting in the same window.That's what I normally do as well, but when you go to the system variable I am looking at, it just changes to a "view position" button. Similar to how a PR is displayed.
Well I was unable to determine the syntax.
I ended up doing in Karel, as much as I didn't want to.
Here's the code (stripped down a bit):
Display MorePROGRAM LNTRKTOPR %COMMENT = 'Line Trk to PR' %NOLOCKGROUP %NOPAUSE = ERROR + COMMAND + TPENABLE VAR data_type, dest_PR , int_value, LNTRKSCH , STATUS : INTEGER LNTRKFRAME :XYZWPR real_value: REAL -- Used only for the GET_TPE_PRM command str_value : STRING[32] -- Used only for the GET_TPE_PRM command BEGIN GET_TPE_PRM(1, data_type, int_value, real_value, str_value, STATUS) LNTRKSCH=int_value GET_TPE_PRM(2, data_type, int_value, real_value, str_value, STATUS) dest_PR=int_value --Get the frame from the commanded line schedule. LNTRKFRAME=$LNSCH[LNTRKSCH].$TRK_FRAME --Set the commanded PR. SET_POS_REG(dest_PR, LNTRKFRAME, STATUS) END LNTRKTOPR
Hi
I'm sorry to reanimate this thread, but it comes close to my problem: dealing with $LNSCH in KAREL
Display MorePROGRAM trsptrkfrm -------------------------------------------------------------------------------- -- -- Transpose Tracking Frame -- -------------------------------------------------------------------------------- %COMMENT = 'Transpose Tracking Frame' %NOLOCKGROUP %NOBUSYLAMP %NOPAUSE = ERROR + COMMAND + TPENABLE %NOABORT = ERROR + COMMAND + TPENABLE -------------------------------------------------------------------------------- -- -- local types & constants -- -------------------------------------------------------------------------------- VAR iSleepTime : INTEGER -- delay in ms bShutdwnReq : BOOLEAN -- program abort requested status fLntTrkFrame : XYZWPREXT -- line tracking frame rRegVal : REAL -- GET_REG output iRegVal, -- GET_REG output iRegStatus : INTEGER -- GET_REG output rRegFlg : BOOLEAN -- GET_REG output entry: integer status: integer CONST LOOP_HZ = 5 -- Main loop freq (Hz) SHUTDWNREG = 461 -- Shutdown register REGSUCCESS = 0 -- Success Status LNTRKSCH = 1 -- Line Tracking Schedule Number -------------------------------------------------------------------------------- -- -- Main program -- -------------------------------------------------------------------------------- BEGIN WRITE('START - Transpose Tracking Frame',CR) bShutdwnReq = FALSE iSleepTime = ROUND(1000.0 / LOOP_HZ) WHILE (NOT bShutdwnReq) DO fLntTrkFrame = $LNSCH[1].$TRK_FRAME --GET_VAR(entry, '*SYSTEM*', '$LNSCH[1].$TRK_FRAME', fLntTrkFrame, status) --IF (status <> REGSUCCESS) THEN --WRITE('GET_VAR Failed',cr,' Status = ',status,cr) --ENDIF --fLntTrkFrame.z = fLntTrkFrame.z + 10 --SET_VAR(entry, '*SYSTEM*', '$LNSCH[1].$TRK_FRAME', fLntTrkFrame, status) --IF (status <> REGSUCCESS) THEN -- WRITE('SET_VAR Failed',cr,' Status = ',status,cr) --ENDIF --$LNSCH[1].$TRK_FRAME = fLntTrkFrame DELAY iSleepTime GET_REG(SHUTDWNREG, rRegFlg, iRegVal, rRegVal, iRegStatus) IF (iRegStatus = REGSUCCESS) THEN IF (iRegVal <> 0) THEN bShutdwnReq = TRUE WRITE('STOPPING - Transpose Tracking Frame',CR) ENDIF ELSE WRITE('GET_REG Failed',cr,' Status = ',iRegStatus,cr) ENDIF ENDWHILE -- Reset Outputs etc SET_INT_REG(SHUTDWNREG, 0, iRegStatus) IF (iRegStatus <> REGSUCCESS) THEN WRITE('SET_INT_REG Failed',cr,' Status = ',iRegStatus,cr) ENDIF WRITE('STOPED - Transpose Tracking Frame',CR) END trsptrkfrm
I'm triing to compile the code with following error message:
Display MoreC:\Program Files (x86)\FANUC\WinOLPC\bin>ktrans trsptrkfrm.ls /ver V8.20-1 Notice: Unable to find 'robot.ini', Using basic KAREL support files. KTRANS Version V8.20 (Build 11 6/19/2014) Copyright (C) FANUC Robotics America Corporation, 1985 through 2012. All Rights Reserved. C:\Program Files (x86)\FANUC\WinOLPC\bin\trsptrkfrm.ls(49) 49 fLntTrkFrame = $LNSCH[1].$TRK_FRAME ^ ERROR Id must be defined before this use. Id: $LNSCH ===============Translation not successful=============== Error executing KTrans: Error translating program: Code: 0xFFFFFFFF: C:\Program Files (x86)\FANUC\WinOLPC\bin>
No matter what variable of $LNSCH i want to adress ($LNSCH[1].$SCALE), i allways get the same error: "Id must be defined before this use. Id: $LNSCH"
So may someone enlighten me... please
Could it be that the file extension you are trying to compile ends with .ls instead of .kl?
