Hello !
I have application with XRC, where is necessary to have small adjustments of XYZ position in play mode.
I am using position variable.
Is it possible?
Hello !
Is it possible?
Use SETE command to change data in Pvar. The data can come from calculation og IO input. Remember it's input as 1/1000
Is it possible to input correction with teach pendent numeric keys in play mode? On other system i have option to change position in play, however correction is limited for 1 mm per cycle. For me is not problem i programing, problem is in changing any variable in play mode with numeric keys.
Please help me
