I have a rather large machine with a lot of ethernet devices. There is a main dell Powerconnect 7024 ethernet switch that I am using to manage all of the ethernet traffic.
In the dell switch I have set up VLANs to cut down on ethernet traffic to the ethernet cards I have on my ControlLogix PLC (3 total).
Now, I have LRMates on this machine with R30iA v7.7 controllers. This is where I'm having trouble......
My PLC is on VLAN 3 with an IP address of 172.16.3.2 for example, my robot is 172.16.4.3 (subnets are set at 255.255.0.0).
My safety CIP connection is working fine, but my normal ethernet I/P connection is going in and out. About 1 second of a good connection and 7 seconds of no connection. I know my PLC is configured correctly since when the switch is at factory settings it works just fine.
Is there something in the Ethernet I/P connection in Fanuc that would not allow VLANs to work? We've had a similar setup before and it worked fine, but I didn't have ethernet safety...
Any suggestions will help.
