Can I use $date.hour in KRC1?
Maldrax -
January 31, 2013 at 10:42 AM -
Hm. I'm sure I ran into this problem once, but I don't recall exactly.
I just experimented on it with a KRC2 running KSS 5.6.6, and it worked perfectly well.
Just for kicks, can you try something like this in your code:
If you can make a copy of the entire $DATE variable, you might be able to access the components of the copy.
SkyeFire, you are the best!
It works very fine. I didn´t try by that way....
You right, if i make a copy, the kss will able to work in any components of this variable...
Thank you so much!!!
