Fanuc program configuration setting
  • Hello,
    I have query regarding Fanuc program download from Delmia.
    When I download a program from Delmia I get the configuration for GP1 (Maingroup), GP2 (Rail) and GP3 (Servo gun) as below
    [color=red][b]GP1:
    UF : 0, UT : 1, CONFIG : 'F U T, 0, 0, 0',
    X = 1141.061 mm, Y = -2020.794 mm, Z = 1736.909 mm,
    W = 35.058 deg, P = -10.368 deg, R = 175.044 deg
    GP2:
    UF : 0, UT : 1,
    J1= 1000.000 mm
    GP3:
    UF : 0, UT : 1,
    J1= 20.000 mm
    But when I download it from Robot online I get the below configuration.
    GP1:
    GP2:
    UF : 0, UT : 1, CONFIG : '',
    X = 0.000 mm, Y = 1000.000 mm, Z = 0.000 mm,
    W = 0.000 deg, P = 0.000 deg, R = 0.000 deg
    GP3:
    UF : 0, UT : 1,
    J1= 20.000 mm, J2= 0.000 mm, J3= 0.000 mm,
    J4= 0.000 mm, J5= 0.000 mm, J6= 0.000 mm
    Can anyone suggest how to get the required configuration in Delmia and what all changes I have to do in the software so that download from delmia can be used directly online without any modification??
    Regards
    Prasun
    Marysville, OHIO
  • Please add more info about your robot.
    Robot model: ie R-2000iB 165F,
    Group 2/Rail setup info: Nobot, linear rail, rotator, # of axis in this group
    Group 3/Servo setup info: Nobot, linear, rotational, # of axis in group
    Also add a section out of an .ls program. Make sure that the program was taught on the teach pendant and runs all axises correctly. Will look similar to this:
    769:L P[586] 317mm/sec CNT100 ;
    770:L P[587] 180mm/sec CNT100 ;
    771: ;
    /POS
    P[1]{
    GP1:
    UF : 1, UT : 1, CONFIG : 'N U T, 0, 0, 0',
    X = 405.02 mm, Y = 1366.24 mm, Z = -783.59 mm,
    W = -178.58 deg, P = 16.41 deg, R = -31.02 deg,
    E1= 5500.00 mm, E2= -1800.00 mm
    P[2]{
    GP1:
    X = 700.20 mm, Y = 1193.29 mm, Z = -823.68 mm,
    W = -175.74 deg, P = 12.80 deg, R = -25.15 deg,
    E1= 5666.00 mm, E2= -1951.00 mm
