I have a system that requires the servo amplifier of the robot be dropped out(locked) when entering the workcell. Anyone know how to do this properly on this new controller?
R-30iB Servo Amplifier Disconnect
- SJT
Your workcell should have a safetyfence or lightscreen, connect that to the FENCE or emergency connections and it will do the job.
I have the same type of customers. Fanuc initially was not going to support doing this, I understand that now they are. I do not have any details yet to share. Kluk Kluk, there are plants that require the servo power to be physically dropped by a servo disconnect switch seperate from any fence/safety circuits.
FYI..... per FANUC, "......as present the R-30iB does not offer a Local/Remote Servo Disconnect Option. If Servo Disconnect is required, we offer this option on the M-410iB/160 R-30iA unit. Therefore, if required, my solution today would be the Remote Servo Disconnect, P/N: R-30iA ME-R30iA-470. It comes with a 7, 14 or 21 meter cable selection allowing mounting of the Remote Disconnect at the edge of the cell. "
Kluk Kluk, there are plants that require the servo power to be physically dropped by a servo disconnect switch seperate from any fence/safety circuits.Really ? O, I did not know that....Seems a bit like overdoing it...
Is that controled by hand or automatic ?
In my case, it's a disconnect the operator would throw and lock out before entering the cell.
Why not simply use a e-stop button that you can lock? Robot in e-stop can't do nothing.
You have a good point. But I as an integrator have to satisfy my customer's requirements.
What robot are you using or is this a blanket question of what to do in general for this controller? In the R30ia (and older) we always connected a 3phase disco switch between the breaker and the CRM2 contactor. We also put aux contacts on the switch that connect to the SD inputs on the interface board. I have yet to look at the controller. We have a new 710 setting on our shop floor. I can get more info soon. I know fanus 'says' they dont support it, be we were told they are going to. I just have to find out more info.
Blanket question for this controller.
Why can't you connect to the servo on/off inputs in the controller?
You have a good point. But I as an integrator have to satisfy my customer's requirements.Note, these are not accepted as requests...but requirements. I have the same type of customer with the same demands. The servo 'SD' connections are used and are connected to a set of aux contacts on the disconnect throw switch box. They break and initiate an E-stop. They also prevent a SRVO-DCLV error because the servo power has disappeared. I still do not have a good answer yet on this. I have an M710-50 on the r30ib controller that will have a servo disconnect attached to it in 2 weeks. I was told that fanuc was supplying this or at least approving this. I need to see what the plant has nogotiated because Im still in the dark a little here.
