Good day,
We used KUKA Robots
KRC 2 ed05
Software KRC V5.6.8
Robot arm KR 16-2
I have a question.
It is possible to change password in EXPERT mode?. Default a password is KUKA. I´d like to change.
Thank you for your answer.
Good day,
We used KUKA Robots
KRC 2 ed05
Software KRC V5.6.8
Robot arm KR 16-2
I have a question.
Change password option is available on left side of teach pendant in log on window..
I have purchased a second-hand KUKA robot.
I don't know the password for expert mode and my seller says....he don't rememeber.
It is possible to reset password?
If you forgot your password there is solution!
There is a program call (KPassSolver) that show you your password.
Send me your email and i will send you ok!
It is easy to use, you just need to insert inside your C: and execute by KCP, it will show you the password!
Can be resetted...do you need the solution in private?
i Have the same problem
Bulo please give the solution too
KSS5.5 and 5.6 do user management from Windows Control Panel
iam too need to change my password. please give me to steps to do it.
Hi all,
I need the solution to reset the safety password. Robot is KRC4.
try this password reset software to reset all your password to default 'kuka'.
Hi! I have the same problem, Would you send me the program to can reset my password @mhasman
Thanks in advace
My email: arely0195@gmail.com
Thanks I could solve the problem. After several attempts we could enter to regedit and delet the password.
Thank for your help
Как узнать пароль для эксперта?
Добрый день !
Не могли бы вы отправить на почту программу KPassSolver
почтовый ящик ryno_17_87@mail.ru
Добрый день !
You shouldn't delete threads.
You shouldn't post email addresses.
You should write in English.
You should at least post which controller, and which options you have.
The passwords on safeOperation robots aren't stored in the registry, so I think the program won't work.
KRC 2 ed05
KRC V5.6.8
KR210
Can you get to Windows level? Its been really long time since i dealt with C2 but i think this is still editable through Windows user management
Hello, by default, when KSS
is loaded, you can only work in KUKA HMI, usually to get to the Windows side
on KRC2, you must first log in, at
least at the expert level, and then
by pressing CTRL+ESC,the Windows Start menu pops up…
If it's not possible to log in to Expert or Admin inside the KUKA HMI, it is possible to boot the robot to Windows without starting the KUKA HMI. Generally by connecting a keyboard and holding the Shift key from the time the Windows logo appears until the desktop finishes rendering.
