Hello everybody,
Can I use CAMRob with a KUKA KRC1 KR125/2 Tj? The KRL version is above 3.
Many thanks in advance for your help.
Hello everybody,
KUKA CamRob doesn't run on KSS 5.X.X downwards.
You need KSS 5.X.X and upwards but KRC1 not supported.
As I noticed CAMRob translate G-Codes to KRL? What is so special in KSS 5.x.x that CAMRob only use that?
Cam-Rob Path output as BIN file and up to 2.000.000 instruction. Multiple BIN file calling by KRL as possible. I think KSS 4.X.X was not compatible this function.
Hi, I've just installed KUKA Camrob and when I try to import a Gcode it gives me an error.
[209] Unsupported command found
I'm trying to import it from a txt file, maybe it should be .tap?
What do you think it's happening? How do I solve it?
Thanks a lot
Hello
But I found a kuka doc that shows we can use camrob with upgraded kss krc1 (please see attached photo).
There are other options such as Kuka PRC by Robotarchitecture:
http://www.robotsinarchitecture.org/kuka-prc
