Robotforum | Industrial Robots Community
Industrial Robot Support and Discussion Center => Nachi Robots => Topic started by: lukem on June 13, 2018, 03:06:46 AM
Title: Nachi AT20 controller safety bypass
Post by: lukem on June 13, 2018, 03:06:46 AM
HI all
at work we are starting to set up and configure robots we brought out of the old Toyota factory in Melbourne.
we have 2 robots running AT20 controllers they were set up with a lot of external safety cutouts and external e-stops.
is there a way we can fit jumpers to the controller to override them so we can test and move the robot? if so can you tell me what pins to connect?
they are also fitted with JSK Robot Safety Controller 24VDC RBS-001-A-C.
any information or help would be appreciated
Title: Re: Nachi AT20 controller safety bypass
Post by: lukem on June 14, 2018, 09:37:25 PM
i have managed to figure out the safety circuits on the controller and how to bypass them.  i will upload a schematic later this week
Post by: jstolaruk on June 16, 2018, 12:45:06 AM
Consider sharing what you found out, helping others that may run into the same issue.
Post by: Elijah Phillips on March 23, 2019, 09:57:53 AM
I'm guessing you mean the AX20 controller?
The safety signals to and from the controller are on TBEX1 and TBEX2 connectors.
See attached installation manual safety signals section.
Post by: knnklnc on April 01, 2019, 01:43:30 PM
If you take that robot from Toyota factory, it's mean this controller has a Toyota spec.
But you can't find TBEX1 or TBEX2 socket on that controller.
Because Toyota spec. is different.
I never used AT controller before, but it can be similar with AW.
You should check X-LINE socket.
This socket using for safety connections.
Also we are using jumper for this socket. (But controller spec is different. You should be carefull)
Please check attached picture for referance.
